96 polaris explorer 300 not getting fuel into the cylinder
You might have just figured my problem out. The plastic housing around the clutch is messed up. When I bought it the guy had the plastic off and the clutch was exposed. He had a can of starting fluid out and I heard it run. since then I have not been able to recreate the issue.
So, I am guessing the reason he had the clutch cover off was because he needed it off to get it started.
Can you explain what he might have been doing to get this to run with the clutch cover off?
#16
Seal #28 is usually the main one to either seep or pop out,plus on #13 you have to pull the flywheel and stator. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
#17
#18
#19
2 stroke engine
#20
That was perfect.. Now I see what you are saying. Do you think the guy was spraying starting fluid into the seal area so that it could draw it in easier?
Side note, I took of the stator plate and the seal looks fine. I inspected the clutch side and I can see oil has been leaking out if it... Do I need to clean out the bottom end or just drain it before putting the new seal in?
