off/run/off switch intermittent
Old Feb 10, 2013 | 12:32 PM
bluesportsman's Avatar
Default off/run/off switch intermittent
Hey guys, went to ride this morning and found the only way my 05 sportsman 400 would stay running is if I pushed in on the off/run switch. I havent an issues with this in the past, it just popped up this morning. I am guessing I have a bad contact somewhere in the switch, just wondering if anyone has had any issues like this, and if this switch is easy to pull apart, or if I should just replace. Thanks in advance
Old Feb 10, 2013 | 04:40 PM
It's about a $70 switch at Cycle Parts Warehouse so it's either try to fix this one or buy a new one or take a chance on a used one from Ebay,etc. I'd try first just to pull the two connectors and clean the contacts inside the switch and on the harness connectors with either electrical spray or just plain rubbing alcohol and q-tips.Then use electrical grease in the connectors. If that doesn't help then you can pull the little plastic plug at the rear of the switch and loosen the small allen screw that snugs the switch to the bars. If you have an air blower you can just pop of the left grip and slide the switch off so you can work on it on a bench. You can pop it apart,but be careful especially on the slide switch and the copper/brass contacts. Possibly you may just have a contact that can be pried out a little to make a better connection or a soldered wire connection that's vibrated loose,barely making contact.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Elkaholic
Sep 6, 2015 02:44 PM
toonces
Sep 5, 2015 01:14 PM
