help, cv shaft install
Old Apr 18, 2013 | 06:39 PM
lawns90's Avatar
Default help, cv shaft install
Hi,
I have a 08 sportsman 500. I removed the rear cv shaft, replaced the boot and can't get the shaft back into the transmition. The c clip is on. Any suggestions. It should slide in. I have put never seize. It seems very difficult to hit it. Any help would be appreciated. The bike is apart. Thanks
Old Apr 18, 2013 | 07:19 PM
Easier if you have the upper a-arm up out of the way then you can have the drive shaft straight. Align it with the splines,push in to compress the cv joints and hit it with a dead blow hammer.It should seat. Or if you have help,just hold it straight and have someone knock it in. Plus you can use a piece of wood and a hammer to keep from damaging the threads on the shaft.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
toonces
Sep 5, 2015 01:14 PM
