250 polaris trailblazer problems
You DON'T have to pull the clutch to replace the cover seal,but you do if it's the engine to backing plate seal.. Look at the break down link I posted,shows all the parts that may be involved!
Only way is to use a flashlight and try to look behind the backing plate at the rear of the rubber seal,but you can't see all of the seal,plus you may be able to look at it closer from the front when you pull the clutch cover.Clutch shaft doesn't need grease,just needs to be clean. Take an air nozzle and blow out all the clutch dust in an open area. Makes a mess.
#17
#19
