atv wont crank without cables???????
Old Jun 17, 2013 | 06:10 PM
predator910's Avatar
Default atv wont crank without cables???????
I Have A 04 polaris predator 500... The atv Will Not Crank Unless i hook jumper cables up to the battery. If I Do Not Hook Jumper Cables To The Battery, It Will act like it wants to crank but wont. The man i got the atv from said it had a bad battery but the headlights and fan will still come on so i was woundering if it had something to do with starter or solenoid, or mabey it is just the battery. What Do You guys Think?
Old Jun 17, 2013 | 07:04 PM
ken cunningham's Avatar
Battery i most likely toast, however you may be able to rescue it by charging it for several hours at a high amp rate. This has worked for me a few times, but not allways.
Old Jun 18, 2013 | 04:43 AM
Charge the battery as suggested,plus even have it load tested if need be. If the battery checks out good,but still has to take a jumper battery to get it cranked,it could be the one way starter clutch starting to wear and drag. Item#7 Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
Jackg17
Sep 26, 2015 09:30 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
