polaris xplorer
Old Jun 24, 2013 | 12:36 AM
catfisherpro's Avatar
Default polaris xplorer
I have a 96 xplorer 400 suppose to be 4x4. I can't seem to get the front drive sprocket off thought there is a pin in it but can't find it. Can someone help I got to get it made.
Old Jun 24, 2013 | 04:25 AM
If you're talking about the very front sprocket,the drive shaft has a spring pin that has to be driven out and the drive shaft removed to be able to remove the front sprocket. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Jun 24, 2013 | 11:53 AM
How do I get it out
Old Jun 24, 2013 | 01:29 PM
Best if you have an air chisel with a small pointed bit.Makes short work of removing the pin. If not, it takes a hammer and a punch and usually busted knuckles to drive the pin out.
Old Jun 24, 2013 | 05:48 PM
Is the pin on the front or back of the sprockett cause I tried to push out what looks like a aluminum pin on the outside. An do I half to remove the u joints
Old Jun 24, 2013 | 05:54 PM
The pin has to be removed,the entire shaft moved back to be able to pull the drive sprocket off. Here's a link to a pdf manual you can down load to help you with.Index of /ORV Manuals/Polaris/1996-1998 - All Models
Old Jun 24, 2013 | 06:02 PM
I can't download the file. Onto another question there is a lil oval container under my seat that's not hooked up to anything u know what it suppose to b
Old Jun 24, 2013 | 08:13 PM
Well heck also have new question that just happened I blew my radiator hose off how do I fix that the lil metal tube came out attached to hose that runs to the head any suggestions
Old Jun 25, 2013 | 01:30 AM
If threads are screwed up you can try JB weld and see if it holds or you can either get a used head or order a new inlet nipple. Item #8.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse The only oval container under the seat that I can think of is the air box! http://www.cyclepartswarehouse.com/f...1996&fveh=5419
Old Jun 25, 2013 | 01:53 AM
I know it's not a air box its in the rear has only one hole in the bottom. An about the radiator hose im probly gonna have it welded back in but thinking while I have the head off I might check the piston out but what are the torque of the bolts
