Temp module
Old Sep 4, 2013 | 05:48 PM
Max4's Avatar
Default Temp module
My son has A 2002 325 Trail Boss , yesterday the heat light came on and the fan started running on high (assuming this has a 2 speed fan) , I unplugged the temp sensor thinking this should stop the fan but it didn`t . unplugged 2 yellow wires nothing changed not sure what the blue wire does , orange wire killed the fan and temp light and red wire slowed fan down when unplugged . Would this mean the the module is gone and where can I get one everwhere I try says they are backordered . I took the sensor out and put heat to it and got resistance reading so I think it is ok.
Kent
Old Sep 4, 2013 | 09:22 PM
Sounds like something a thermistor module would do. If they get real hot you can usually see a bulge in the plastic case or it will be melted in the back. Don't know the availability here.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
shimanok2
Jan 29, 2016 07:37 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Halffast17
Sep 11, 2015 02:30 PM
