Motor Issues...
Old Sep 19, 2013 | 12:33 PM
bjones12's Avatar
Default Motor Issues...
Riding my 700 Sportsman last weekend I noticed a knock starting to form, as I rode it back to the trailer it got louder and louder. I feared it was the push rod bearing or the cylinder rings. After checking to make sure it was not the clutch, I began tearing down the top end of my quad. Nothing looks beat or malfunctioned. As I got to the cylinders (before tear down it had 85 psi) they were smooth with no scratches no signs of wear. As I moved down toward the crank I noticed that the push rods had a little play in them. Doesn't seem like enough play to be causing such a loud knock, WHAT COULD IT BE??????????
Old Sep 19, 2013 | 02:28 PM
Sounds like you may have to go deeper than the pistons. Seems like I had more rod problems on the 700 and the early 325 engines than any other machine. If in fact it's a rod bearing making the noise,kits are available now to rebuild your crank through place like Hot Rods.There should be no up and down play on the connecting rods.
Old Sep 20, 2013 | 06:26 AM
bjones12's Avatar
The crank looks to be a one piece unit??? Is there a link you can post for hotrods? Thanks OPT
Old Sep 20, 2013 | 06:36 AM
They have plenty of cranks and lower end parts kits for the 800 that a machine shop could install,but you need to call them about the 700 parts kits availability. The difference between the 700 and 800 was the stroke. Hot Rods, Inc.
Old Nov 5, 2013 | 07:36 PM
bjones12's Avatar
Well no luck finding anyone who can service the crank shaft on the 700. And it seems that replacing it, and all other parts and gaskets associated with a complete rebuild may be too $$$$$ consuming. Can anyone help with places that sells rebuilt engines?
Old Nov 5, 2013 | 07:43 PM
woodsmen3417's Avatar
What year ?
Old Nov 5, 2013 | 07:46 PM
bjones12's Avatar
Old Nov 5, 2013 | 07:54 PM
I have a 2002 700 myself I'm having problems with it also but finding a rebuilt engine is scarse in that model I know you would hate to go through tearing it apart but that most likely what your gonna have to do ..I could look online for one ill keep you posted.
Old Nov 5, 2013 | 07:56 PM
bjones12's Avatar
Ok thanks!
Old Nov 5, 2013 | 11:14 PM
http://pages.ebay.com/motors/link/?nav=item.view&id=251371014273. This is only one I could find its from an 03 sportsman but motors are the same..But for the price ..I would get a overhaul kit and rebuild it ..
