Starter filling with oil and leaking? WTF!?!?
Old Jan 7, 2014 | 01:11 PM
09' Sportsman XP 850's Avatar
Seems if it was a crank seal on the flywheel/stator end though that it would foul out the stator and wouldn't run at all.Didn't have much time on this engine as I retired before any major problems came up other than the crank case vent problems.Got me baffled too..
I was thinking possibly a crankcase vent line was plugged, thus causing high pressure and somehow blowing oil into the starter area...
Old Jan 7, 2014 | 03:52 PM
Possible since the 2009 through 2011 models did have crank case vent problems and all parts were updated. Usually the air boxes had a lot of oil also. You might check that to. Almost all parts were updated and I remember we had some early attempts from Polaris to fix this. Most people went to 2012 parts.Here's the recall if you haven't had this done.Polaris ATV, Snowmobiles, RANGER, Victory
Plus look at all the updated part numbers!http://www.cyclepartswarehouse.com/f...009&fveh=30474
Old Jan 7, 2014 | 05:05 PM
Plus look at all the updated part numbers!Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
My air box did have oil issues when it was new, the dealer fixed that though. Any chance you'd know where to find the crank case vent?
Old Jan 7, 2014 | 06:00 PM
Just took the starter back out, and I can see oil on the teeth of the flywheel as well as oil/dirt on the housing/block... shouldn't this be dry?
Old Jan 8, 2014 | 09:38 AM
  #15
Should be.
Old Mar 22, 2026 | 11:33 PM
  #16
Michelle0581's Avatar
Originally Posted by 09' Sportsman XP 850
So I tried to start my 2009 850 XP around Christmas time and it was cold here in here in Hell (-40ish), the bike wouldn't roll over at all however the starter would engage, just not spin. So I pushed it into the garage and let it thaw out for a day, once it was warmed up it started right up, then I discovered there was oil leaking out of the starter. I plowed my driveway for a few minutes and noticed the oil was leaking faster and faster as I went on.
I took the starter off and took it to the local motor/starter shop, the guy said it was in great shape and couldn't find a problem with it, so I took it home and reinstalled it, and of course it is still leaking oil...
Anyone have any idea's?????
I know I’m a girl but I had this same problem today and I live in Florida where it don’t freeze. I believe it’s too much oil in atv. When too much oil is in there it enters crankcase and turns into foam. Which will find weakest spot (starter seal) and leak. You can check by removing starter and while starter is off and atv is off try pulling the pull cord I had oil shoot out where the starter goes. The oil appeared metallic to me. I drained oil and refilled correctly and I’m going to try cranking it in morning I’m not sure if it messed up my starter or not though. And I’m not sure what other damage this caused.
So I just thought I’d give you the info I discovered hope it helps
Old Apr 4, 2026 | 12:04 PM
  #17
Red64's Avatar
Default Oil
There is n oil inside of any model of these starters. They are not oil bath electrical motors. If you had oil leaking from the actual starter the then the oil found its way there from another source. Possibly an over filled crank case from a previous oil change service or something.
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Shainasmash
May 8, 2017 06:38 PM
WesTech
11
Aug 11, 2015 07:55 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
