Shift Rod Linkage
Old Jan 28, 2014 | 10:10 AM
Bkumler's Avatar
Default Shift Rod Linkage
Hello, anybody every make a homemade shift rod linkage? Can you just buy the proper strength steel rod, cut it to length and thread the ends? I am a contractor, so I have the tools to do it, I would just need to buy the steel rod.
Anybody know the strength or gauge of steel rod Polaris use?
My linkage is bent and the prices for new or used ones seem crazy.
2002 Polaris Scrambler 500cc 4X4
Old Jan 28, 2014 | 11:22 AM
22 bucks here. Cheaper,quicker than trying to scrounge up the parts to make one. Item#10. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Jan 28, 2014 | 08:30 PM
Bkumler's Avatar
OPT, true one the models built before 8/01. But unfortunately I have the other linkage 1821206 , built after 8/01. $38 seems kinda of steep for 5/16 steel rod thread on each end.
PS I have read many other threads on this forum and your know is great. Thank you for all that you share. I greatly appreciate.
Old Jan 29, 2014 | 08:58 AM
scootergptx's Avatar
Supersock
Hired Gun!
Can't say how well it would work, but they sell aluminum rods at home depot. Maybe steel too, but not sure on that. Cut it to length and thread it.
I know the aluminum stuff bends pretty easily on the smaller diameters.
Old Jan 29, 2014 | 07:35 PM
Bkumler's Avatar
Scootergptx, I agree with your thoughts about the aluminum and steel rods from the big box stores. I would go to a commercial supply store that would sell harden steel rods like, Fastenal. I have already looked and I can buy a harden 2' Stella rod for about $8-10.
Old Feb 1, 2014 | 09:13 PM
TaterTots's Avatar
I replaced my low range linkage with a piece of Skidoo steering linkage. The low range length is about 16", so I was able to adjust it to the right length and put the proper size bolts through the heim joints. I put a thin strip of rubber around the bolt to take up the little bit of slop between the heim joint & the relatively small bolts that fit in the gear selector & pivoty thingie.
I bought it used on ebay for $8 shipped. Considering the stock replacement linkage is about $40 and the heim joints another $20-30, it was a bargain.
95wolv
Sep 27, 2024 12:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
