20 amp circuit breaker on 2003 sportsman
This is the circuit breaker in the pouches under the headlight pod. Can I switch these out to 20 amp inline fuse instead? Would be easier than trying to find one of the stock breakers. Thoughts? Thx
The breaker under the front panel is a 10 amp breaker for the fan. The main breaker up from the battery is a 20 amp. I've had people install water resistant fuse assemblies before,but be sure to carry a few spares if you do.Polaris used the thermal circuit breaker because it would usually trip if you had a problem and reset,but I guess they didn't count on the moisture that would short one out.
I got the same exact breakers When I received it it was exact same part # and Brand as in the bag for my 03 700 from Del City - Electrical Supplies & Professional Grade Wiring Products for $1.99
Item
72325 20 Amp Auto Reset Metal Circuit Breaker
Cut the bag open and change breaker fill bag with Silicone caulk and electrical tape the bag shut.
Item
sweaver
11
Aug 18, 2015 03:47 PM
bpegram84
Jul 22, 2015 08:15 AM
