Magnum 325 Oil Change..
Hi there,
Just changed the oil on my machine, and according to the manual, it tells you to add 1.9 quarts of oil to fill it up. I did so, and it wasnt full. I ended up needing about 2.5 - 3 quarts to fill it. Is this right?
Also, how many grease fittings should I be looking for? I want to make sure I have them all!
Thanks!
Thanks!
I HAVE A MAGNUM 325 4X4 ALSO,ON THE OIL CHANGE SOME OF THE OIL GOES IN TO THE OIL COOLER.I JUST ADDED ENOUGH TO PUT IT TO THE FULL MARK.I ALSO RUN IT SOME THEN CHECK IT AGAIN.AS FOR THE GREASE ZERKS ,I THINK THERE IS 12 ON THE 325.I KNOW THE SPORTSMAN HAS MORE BECAUSE OF THE REAR END.I HOPE THIS HELPSAND IF I CAN HELP ANYMORE FELL FREE TO E-MAIL ME.GOOD LUCK.
09-09-2015 06:57 AM
