Replacing parts??? Advice
Old Apr 29, 2014 | 06:24 AM
Biggfish's Avatar
Default Replacing parts??? Advice
I hav a 02 scrambler 500 4x4. Im having my rear swing arm bushings changed and figured havin drive belt replaced as well. I see there r a lot of belt options out there. Im looking to replace it with the best i can find. Any preference on belts and bushing kits i should get. I see moose belts r ribbed on both sides and others r not??? I dont get it
Old Apr 29, 2014 | 05:06 PM
user493's Avatar
Moto Psycho
I don't know about bushings but the OEM belt seems to work the best.
Old Apr 29, 2014 | 05:42 PM
Biggfish's Avatar
I figured oem would be the best. Im changing bushings cause i thought they were worn cause when i rock it side to side im seeing movement. It appears the that the inner bolt on the left side moves off the frame. Im assuming that the outer bolt is loose. So should i still replace bushing or just torque the outer bolt and call it a day??
Old Apr 29, 2014 | 06:20 PM
Pivot bolts have a habit of backing off. Replace the bushings as they're only a little over 4 bucks each,plus have had an update on them.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Rocketx
Nov 16, 2020 07:25 PM
hugemoth
Jul 20, 2020 03:28 AM
jgiljr
Aug 21, 2015 06:15 AM
bikedad3
Jul 2, 2015 02:15 AM
