04 magnum 330 4x4 top speed
I got a 04 magnum 330 4x4 and if u hold it wide open it has a top speed of only 30 mph and the motor revs up like crazy to do this, is this the top speed or is the belt or clutch bad.
you should remove the belt cover and inspect the belt. Clutches may also not be aligned. Check ur FSM for diagnosis an repair procedures for all this. Luck! :banana:
Index of /ORV Manuals/Polaris
Probably belt as mentioned along with worn down rear clutch ramp buttons. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Sep 9, 2015 06:57 AM
