2000 polaris magnum Transmission
Hey there old polaris Tech I have a quick question to ask. I have a transmission out of a 2000 polaris magnum 325 model# 1341296. I am wondering if it is the same transmission for a 2001 polaris magnum 500
. The model # is 1341363. I am wondering if these transmissions are the same just a different model number for each year? Or do they have different gear ratios from the 325 to the 500? thanks
Doesn't show that they share the same #,but doesn't mean it can't be swapped. Mounting issues would be the main problem,but both models look like they have the same mounting brackets on the parts break down.Always expect some hangups when swapping anything around. 500 lists a 2x4,but does show to be a 4x4 on the breakdown.
Usage : 1341296
Year Product Model Assembly
2000 ATV MAGNUM 325 4X4 MAIN GEARCASE - A00CD32AA
2000 ATV 325 MAGNUM 4X4 HDS MAIN GEARCASE - A00CD32AA
2000 ATV 325 MAGNUM 4X4 HDS II MAIN GEARCASE - A00CD32AA
Usage : 1341363
2002 ATV MAGNUM 500 2X4 HDS GEARCASE (Not All Internal Service Parts are Readily Available) - A02CB50FC
2002 ATV MAGNUM 500 2X4 HDS GEARCASE (Service Replacement Asm.) - A02CB50FC
2002 ATV MAGNUM 500 MAIN GEARCASE - A02CD50AA/AB/FB
2002 ATV MAGNUM 500 RMK MAIN GEARCASE - A02CD50AA/AB/FB
2002 ATV 500 MAGNUM VL HDS MAIN GEARCASE - A02CD50AA/AB/FB
2001 ATV MAGNUM 500 MAIN GEARCASE - A01CD50AA
2001 ATV 500 MAGNUM 500 HDS MAIN GEARCASE - A01CD50AA
Usage : 1341296
Usage : 1341363
