1994 Polaris 400L 4X4 Top End Speed
Nope.. The motor mount has threads and a steel plate molded into each side of the solid motor mount.Epi Motor Mount Polaris EPISN154 PU | eBay
I have rebuilt my polaris 350l 4x4 to original specs and it will do 60 on the flat about 67 down a hill have you looked on the screw on the right side of carb mine backs out allot that is your idle set screw quarter turn off that and perfect
[QUOTE=old polaris tech;3251252] and also the simple fact its 20 years old.I don't run as good as I did 20 years ago to say the least either.
Now OPT, that's a perfect quote!!! I say it a bit different, every 10 years my brain tells me to slow down 5 MPH, and being in the 50's age group, it's hard to see 50MPH on anything ridden in the dirt these days, I'm sure when 60 hits, my boys might take away my dirt toys for good, as their wait time will out weigh ride time!!!
#15
Brand new out of the crate with stock tires the 400 2x4 would hit right at 65 on a straight road we had by the side of the shop. 4x4 was a tad slower because of the extra weight
I rode with a 400 Xplorer pretty well the same as a 400 Sportsman and it was slower then my 500 on the top end. Unless it was not running right.
My friends 700 Sportsman is lucky to hit 65.
#17
Just order the motor mount from ebay,Cycle Parts Warehouse or a local dealer would usually have them in stock if you're close to one. Idle screw is just as it's described,just turn in or out until you have a steady idle,but with the broken mount it's going to vibrate any way.
#18
So I took the Polaris down the road tonight. Ended up blowing the front right tire. As I slowed down I noticed the bike losing power. It died. Trailered it home and now it won't start. Any ideas other than checking for spark or should I start there. I did use the pull rope for the hell of it and noticed it seems tougher to pull but the electric start spins right up.
#20
Pulled everything off, pulled the plug, put my finger over the hole, and nothing. Wouldn't even blow my finger off. Connected the compression tester and absolutely nothing registers. Guy I bought it from said it could possibly be reeds. Is that a possibility or am I rebuilding the top end?
