99 polaris trailblazer 250
I have a Polaris trailblazer 250 that had low compression. took it to a shop to have new rings and piston put in. now I kind of have a hard time starting it. it needs a starter so I have to use the pull start. when I do get it started I have to keep my thumb on the throttle. and is kind of sluggish when I try to rev it up. and another thing it does when I ride it is after awhile it will lose all power. and to get it to go again I have to hit the throttle wide open and feather it. then after that it will drive fine for awhile then do it again. what could be the problem.
Leak down test best way to check seals,gaskets for leaking,but I'd rebuild the carb first and see if that solves the problem. Air screw usually around 1 1/2-2 turns out, idle screw just adjust to where you have a slow steady idle.Carb Repair Rebuild Kit Polaris Trail Blazer Trailblazer 250 96 97 98 99 00 01 | eBay
Plus plenty of carb cleaning videos on youtube.http://www.youtube.com/watch?v=AOJlH...feature=relmfu http://www.youtube.com/watch?v=wfVQUBO7LjQ
Plus not a bad idea to check compression even with the new top end to eliminate it as a problem. New top ends should be around 135 psi or so on average. If considerably less,may have a problem there.
I just used old cheap wally world electrical contact cleaner as it does basically the same thing and I was a little nervous on using ether. You can spray it around the base gasket,head gasket,intake boot and case seams and you can tell if the engine rpms change along with smelling this stuff through the exhaust if it does suck into the engine. Problem on the crank seals you can't do the stator side crank for the obvious reason while it's running and on the drive clutch side you have to remove the clutch cover and the clutch to really get a good shot at this seal. When you do this you're already there.. Might as well replace the seal since you're looking at it and it just pops out and a new one tapped in place. Try around the external area first and see if could be the intake manifold or gaskets. Plus another thing is the carb itself could be the problem. When you rebuilt the top end,if the carb wasn't rebuilt,possible that it could have been the problem all along. That's a few of the reasons when I rebuilt an engine I rebuilt top and bottom both(along with new crank seals) and carb kits. I got burnt on a couple that I just did top ends that came back on me and wouldn't guarantee another partial rebuild! I just didn't like tracing down problems after I already worked on them.
