need help
Old Sep 9, 2014 | 03:55 PM
Chris Case's Avatar
Default need help
My kill switch broke on the handle bar.on my 95 sportsman.my buddy gave me the whole kill,light,override start switch assembley off his 96 xplorer.His override is on top my override is on the bottom.all the wire colors are the same except his has an extra red with black stripe wire.can i use this on my 95 and just hook up this extra wire?and if so where?or just delete this wire?my kill switch has 2 wires black and brown his has black brown and 2 reds.(inside).any help on if this will work or how to put just the kill switch in my control would be great.thanks.
Old Sep 9, 2014 | 07:01 PM
Your part # is used on several different models,but the 96 is different as you've seen. Here's all the applications and I'd try to find one from one of these model machines that will hook up right. Usage : 4110157
Year Product Model Assembly
1995 ATV XPLORER HANDLEBAR and HEADLIGHT POD ASSEMBLY XPLORER 4X4 W959140
1995 ATV SCRAMBLER 4X4 HANDLEBAR/HEADLIGHT ASSEMBLY Scrambler W957840
1995 ATV 300 2X4 STEERING - HANDLEBAR 2X4 300 W957530
1995 ATV 400L 2X4 STEERING - HANDLEBAR 2x4 400L W957540
1995 ATV TRAIL BOSS 250 STEERING - HANDLEBAR Trail Boss W958527
1995 ATV NORWEGIAN MAGNUM 4X4 STEERING - HANDLEBAR - W958144
1995 ATV SWEDISH MAGNUM 4X4 STEERING - HANDLEBAR - W958144
1995 ATV MAGNUM 4X4 STEERING - HANDLEBAR - W958144
1995 ATV 300 4X4 STEERING - HANDLEBAR 4x4 300 W958130
1995 ATV BIG BOSS 6X6 400L STEERING - HANDLEBAR 6x6 400L - U.S. W958740, SWEDISH S958740 and NORWEGIAN
1995 ATV MAGNUM 2X4 STEERING - HANDLEBAR Magnum 2x4 W957544
1995 ATV SPORT 400L STEERING - HANDLEBAR Sport 400L W958540
1995 ATV SPORTSMAN 4X4 STEERING - HANDLEBAR Sportsman 4x4 W958040
1994 ATV 400L 4X4 STEERING - HANDLEBAR 4X4 400L W948140
1994 ATV 300 2X4 STEERING - HANDLEBAR 2x4 300 W947530
1994 ATV 400L 2X4 STEERING - HANDLEBAR 2x4 400L W947540
1994 ATV 300 4X4 STEERING - HANDLEBAR 4x4 300 W948130
1994 ATV 400L 6X6 STEERING - HANDLEBAR 6x6 400L W948740
1994 ATV NORWEGIAN 400L 6X6 STEERING - HANDLEBAR 6x6 400L, SWEDISH S948740 and NORWEGIAN N948740
1994 ATV SWEDISH 400L 6X6 STEERING - HANDLEBAR 6x6 400L, SWEDISH S948740 and NORWEGIAN N948740
1994 ATV SPORT 400L STEERING - HANDLEBAR Sport 400L W948540
1994 ATV SPORTSMAN 4X4 STEERING - HANDLEBAR Sportsman 4x4 W948040
1994 ATV W948040 STEERING - HANDLEBAR Sportsman 4x4 W948040
1994 ATV NORWEGIAN 400L 4X4 STEERING - HANDLEBAR SWEDISH 4x4 400L S948140
1994 ATV SWEDISH 400L 4X4 STEERING - HANDLEBAR SWEDISH 4x4 400L S948140
1994 ATV TRAIL BOSS STEERING - HANDLEBAR Trail Boss W948527
1993 ATV SPORTSMAN 4X4 STEERING - HANDLEBAR Sportsman 4X4 / W938039
Several used ones on ebay around 25 bucks or less and a new one for 75 bucks.http://www.ebay.com/itm/Polaris-400L-Scrambler-Sportsman-Xlporer-LH-Handlebar-Switch-4110157-/271535986370?pt=Motors_ATV_Parts_Accessories&hash=item3f38ce56c2&vxp=mtr
