thanks for the help, Old Polaris Tech
Old Oct 11, 2014 | 07:13 PM
fivesam20's Avatar
Default thanks for the help, Old Polaris Tech
New to the Forum, able to fix my neighbors Daughters Sportsman 90, after reading the threads. My 2007 ranger 700 needs a new TPS. Dealer said I would have to by the whole throttle assembly. Any suggestions?
Old Oct 11, 2014 | 07:33 PM
Would only need a complete throttle body as if it was damaged as the tps is available separately. May be he doesn't know how to install a tps replacement?? The actual tps sensor itself shouldn't need replacing unless someone has tampered with it and moved it too far,damaging the internal spring in it or damaged the "tamper proof"throttle screw on the throttle body.Then I'd be inclined to say myself replace the whole throttle body assembly.http://www.cyclepartswarehouse.com/f...007&fveh=11382
Old Oct 12, 2014 | 01:32 PM
fivesam20's Avatar
Default My error old Polaris Tech
Busy day yesterday, working on too many things. I meant to say that I needed an ETC for a Sportsman 90,without buying the entire throttle assembly
Old Oct 12, 2014 | 02:49 PM
Not listed separately from the throttle assy. Either one from a dealer or keep a check on ebay for a good used one.
Old Oct 12, 2014 | 06:36 PM
fivesam20's Avatar
Thank you
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
TheHood
Jul 26, 2015 09:51 AM
maxjung
Jul 23, 2015 08:37 PM
