01 trail boss 325
Picked up this 4 wheeler for a project since its to cold to do much else on my days off.
The guy said it started acting like it was not getting fuel, so he trashed the cdi thinking it was the cause and realized a new one cost to much.. I Have since replaced every fuel line, bought working used CDI.
Issues I'm having:
1. I forgot how the fuel lines hooked up..
I had this diagram sent to me and i hooked up all the lines like in the image (guy said hook rear tank line to reserve). The only thing that happened was fuel went to petcock, but that's where it stopped and just leaked at fuel petcock. No fuel went out from that point on(nothing getting to carb).
2. Not sure if its getting spark, hard to test with just the pull start.
Any tips would be great.
That's actually carb cleaner i dumped in, not gas.
Completely clogged
... yeah...
Carb is all cleaned and ready to go now.
Issues I'm having:
Completely clogged
... yeah...
Not uncommon for the fuel valve itself to be stopped up especially by looking at the condition of the carb. If you've cleaned the carb,fuel tank filters(nasty) have the lines routed correctly,the valve could be the problem. OR can be a fuel pump problem also. Take a Mityvac to the impulse(vaccum) line at the carb,turn the fuel valve on,pull the line at the carb and give the Mityvac a good pumping. If fuel doesn't come from the carb hose,then you may need a fuel pump along with a new fuel valve to replace the leaking one.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Plus if you've just cleaned the carb and still have problems,install a new carb kit.http://www.ebay.com/itm/Polaris-Trail-Boss-325-2000-2002-Carb-Carburetor-Rebuild-Kit-Repairs-3131147-522-/231445074505?pt=Motors_ATV_Parts_Accessories&hash=item35e3339249&vxp=mtr On checking for spark just lean the plug up against the cylinder and crank the engine over. You can tell pretty quick if it sparks or not.
Not uncommon for the fuel valve itself to be stopped up especially by looking at the condition of the carb. If you've cleaned the carb,fuel tank filters(nasty) have the lines routed correctly,the valve could be the problem. OR can be a fuel pump problem also. Take a Mityvac to the impulse(vaccum) line at the carb,turn the fuel valve on,pull the line at the carb and give the Mityvac a good pumping. If fuel doesn't come from the carb hose,then you may need a fuel pump along with a new fuel valve to replace the leaking one.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Plus if you've just cleaned the carb and still have problems,install a new carb kit.Polaris Trail Boss 325 2000 2002 Carb Carburetor Rebuild Kit Repairs 3131147 522 | eBay
Yes, the carbs where pretty nasty, but not as bad as i expected. Cleaned tank, carbs, and replaced all fuel lines with new one. To bad i forgot to take a picture of the fuel line routing be for disconnecting, lesson learned.
The new issue is I'm positive there is no spark. I cant test spark the old fashion way with spark plug since I have no one here to watch it as i pull start. How would you suggest testing it?. The coils are cheap, but hate to toss parts at it without knowing the exact issue. Surely it does not need a charged battery for the coils to work(current one does not hold charge).
Best to have the schematic and troubleshooting guide in the manual. Fairly easy to check resistance on the stator and coil to see if they're the problem or something else.Plus good for service and other repairs. Hard to find a cheap one for the first year model 325,but the 2002 didn't change that much. 2002 Polaris Trail Boss 325 Service Manual PDF Download Plus one of the simple things that can kill spark is if the throttle slack is too much that allow the etc contacts to touch. Make sure you have no more than 1/8" slack at the thumb lever.
I downloaded that service manual, should come in handy. Throttle slack is good as far as i could tell, hardly any slack to it.
I just wonder if the split fire spark plug that last owner installed could be the issue, it does not look as if its ever fired. None the less, i will start testing the ignition system when all this cold weather moves out.
stick with the NGK BKR6ES spark plug that came with it from the factory.There's no better spark plug around.
