Need some help Trailblazer 250
Old Feb 28, 2015 | 10:32 PM
Montrell Croff's Avatar
Originally Posted by stendori
you should have at least 120 psi. with the tested installed air tight, you should (with key off) crank over the engine for about 5 seconds with the throttle wide open for best results. engine should be cold(not have been run)
Thanks will give that a shot and let you guys know what happens..
I look at the intake boot that goes to the carb. It looks like it only cracked up on the outside but doesn't go all the way threw to the inside.
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
