Anyone Use Dirt Devils? Better then bearclaws?
Old Apr 10, 2001 | 04:53 PM
harleydude's Avatar
Like I said I can go where ever he goes with no problems,and my dirt devils where alot less. Rockey Mountain has the best price.
Old Apr 11, 2001 | 09:01 AM
DaBoss's Avatar
Do you guys know what the weight difference is between the Titan 489's and the Dirt Devils or Bear Claws (22x10x11 size)? Is there enough weight difference to make a difference in performance of my 00 TBoss (only putting them on the back)?
Old Apr 11, 2001 | 09:47 AM
BK's Avatar
BK
Tiresunlimited.com has there tires listed with the weight. I always go there to check. I know the Titans weigh about 5 pounds less than Devils which I think weigh another 4-5 pounds less than the Claws. Another tire to consider if you want to keep weight down is the Sur Tracs. They weigh about the same as stock.
Old Apr 11, 2001 | 10:42 AM
exprider's Avatar
Yet another one to consider is the kendal rampage. These were on a used quad I bought and they have about 50% of tread left and boy do they pull! I was going in all the ruts and holes the 4x4's were and I did not get stuck.. I have a trx300 2x4.. I will either get the kendal rampage or the sur tracs.!
Old Apr 12, 2001 | 04:24 PM
  #15
DaBoss's Avatar
Is the ride going to be rougher on the DirtDevel(6 ply) than the BearClaw(4 ply)? My TBoss is rough enough as it is. Anyone know if I would have a problem mounting 22x12x10 BearClaws on my Boss (the titans are 22x11x10)?
Old Apr 12, 2001 | 04:59 PM
  #16
bubba1005's Avatar
they will fit as far as the ride goes I don't know.
Old Apr 13, 2001 | 07:24 PM
  #17
SteveXplor's Avatar
Canadian bucks my friend.Around 410.00 for both types installed.Like i said both are good tires but i prefefer the bearclaws.Steve
Old Apr 15, 2001 | 12:31 PM
  #18
harleydude's Avatar
I think my dirt devils ride better then the stock tires.as for the size they should fit just a little wider.
Hondapolaris8596
Jul 28, 2016 03:17 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
