2007 Scrambler 500 winding noise
Old Jun 9, 2015 | 10:20 PM
ranvette's Avatar
I would think it would be hard to tell if it was belt noise or from the trans area.seems most of these i hear have some belt whine.But you did say no noise in reverse.So i would say its what ever bearings are under load? in foward range? Be interesting to see what the fix is. How many miles is on it.I know in the car repair buisness we generally see some traces of metal in the fluid with trans noise problems. But not in all cases
Old Jun 10, 2015 | 02:09 AM
ALWAYS replace the silent chains since you're already in there. They should be fairly tight with no appreciable slack.Pull the gears out,check the shift forks,engagement dogs on the gears.If the dogs are worn down replace the gear along with the mating gear.Slowly turn each bearing to feel if there are any rough spots.At times all I've had to do is just replace the chains and seals if everything else checks out ok.Reverse is normally gear to gear driven and usually doesn't make noise like the chain driven forward gears.
Old Jun 10, 2015 | 11:34 AM
ranvette's Avatar
Than i would assume there must be a fair amount of miles on this machine if the chains are loose like that ?
Old Jun 10, 2015 | 11:43 AM
mpcop077's Avatar
No idea how many miles are on it. These don't have speedometers or hour meters. By looking at it and seeing the shape of the rest of the quad, I wouldn't think so. It's super clean and tight all the way around. Seems to have been taken care of for the most part. I'll post some pictures of it later when I get on my computer
Old Jun 10, 2015 | 03:08 PM
  #15
Problem on these sport machines are that most are driven harder than a utility atv. A lot of stress on chains,gears,bearings belts and clutches.
Old Jun 10, 2015 | 05:20 PM
  #16
ranvette's Avatar
ah i see i didnt know that looks like there 2 wheel drive to
Old Jun 10, 2015 | 05:24 PM
  #17
ranvette's Avatar
plus a more powerful engine to than like what i have a Sportsman 400. all makes sense now
Old Jun 10, 2015 | 08:30 PM
  #18
mpcop077's Avatar
Clean as hell. Got some parts ordered today. Should have them by early next week.
Attached Thumbnails 2007 Scrambler 500 winding noise-screenshot_2015-06-10-20-57-35.png   2007 Scrambler 500 winding noise-screenshot_2015-06-10-20-57-39.png   2007 Scrambler 500 winding noise-screenshot_2015-06-10-20-57-32.png   2007 Scrambler 500 winding noise-screenshot_2015-06-10-20-57-29.png   2007 Scrambler 500 winding noise-screenshot_2015-06-10-20-57-21.png
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
Ahtatu
Sep 28, 2015 12:14 PM
Sep 23, 2015 06:23 AM
