Looking for advice on engine rebuild
Old Jul 14, 2015 | 09:27 AM
jgiljr's Avatar
I have one bolt left to split my case apart on my 03 sportsman 700. There is a rubber mount in my way I can't get a wrench on it it's too tight a fit. Only thing with some force I can get on is a 1/4 in socket with extension. I am afraid I am going to snap the wrench the bolt is on so tight. I can't get anything else on it. I am sure you ran across this how do you pros do it?
Old Jul 14, 2015 | 11:57 AM
Which mount you talking about? Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Jul 14, 2015 | 12:39 PM
jgiljr's Avatar
Number 31 the rubber mounting. The rubber will not knock off and it is a stud into engine compartment.
There is one bolt right underneath that. you can't get a wrench on it. A socket will fit but no room for anything else. I can get a 1/4 in socket and extension about 9/10 the way on if i pry it to compress the rubber. But I need something with a little more beef to crack the bolt loose. Or should I just risk breaking the 1/4 setup.
Old Jul 14, 2015 | 02:43 PM
You do have the engine out of the frame,correct? If not,that aint the way to split the engine.
Old Jul 14, 2015 | 02:47 PM
  #15
jgiljr's Avatar
Yep lol It's sitting on my bench...
Old Jul 14, 2015 | 02:57 PM
  #16
Just take a big old pair of channel locks and grab the engine mount on the metal part close to the engine and remove it. It's not a solid mount.Each stud end is molded into the rubber.
Old Jul 14, 2015 | 04:32 PM
  #17
jgiljr's Avatar
Ok i will try again . Guess I was just not tugging hard enough. Thank you!
Old Jul 14, 2015 | 05:44 PM
  #18
jgiljr's Avatar
Crap Put a huge set of channel locks on her. Got her to start spinning and then snap there goes the stud...
Old Jul 15, 2015 | 11:24 AM
  #19
Oooops,that usually doesn't happen.. Now you get to drill out the old stud. If you don't have a set of these,I'd get a cheap set. http://www.ebay.com/itm/15pcs-Screw-Nut-Extractor-Set-sk-1037B-BOLT-REMOVER-/181660902688?hash=item2a4bd56520&item=181660902688&vxp=mtr Plus these are great if you have enough of the stud to pull. Should be able to get them at Harbor Freight,Northern or a good auto store.http://www.ebay.com/itm/4-PC-STUD-PULLER-REMOVER-WRENCH-SAE-SIZES-SOCKETS-/290598205316?pt=LH_DefaultDomain_0&hash=item43a900b784 Both have come in handy for me over the years.
Old Jul 15, 2015 | 12:05 PM
  #20
jgiljr's Avatar
Yes I have some work to do now. Guess it's just all part of the fun. Last time I used an ez out I snapped that too. What a project getting that out!
