Belts and more
Old Nov 6, 2015 | 05:37 PM
thatguy87's Avatar
Default Belts and more
I am thinking of putting on a new belt before winter comes..still have the original on my 06 magnum...even after all the plowing and 4 wheeling it is still in pretty good condition... What brand belt should I go with? I ain't buying one from a dealer.. I want to replace the rear shock soon too cause its seeing its age and want to put a new one on but can't seem to find any aftermarket shocks anywhere... I can only find the oems, if I special order them from polaris. Does anyone have oil filter part numbers besides the polaris brand.. I'm sure that there are cheaper filters than the $10 polaris ones.
Old Nov 6, 2015 | 06:13 PM
Plenty of filters that cross reference.POLARIS 3084963 - Alternative oil filters Most people will still say to stay with an oem belt because they fit better and in most cases last longer. If your oem belt is fairly good after 9 years that ought to say something about Polaris 3211077 belts.
Old Nov 6, 2015 | 09:49 PM
everythingatvutvreviews's Avatar
Have had good results with Gates G-Force belts and replaced one on a 2012 RzrS with no complaints. Cost effective and reliable. If obtainable, Wix filters have always been my choice.
Old Nov 7, 2015 | 04:27 AM
greg74's Avatar
Oem belt is usually the way to go on any cvt machine. They might be a little more expensive than some aftermarket options but they will last longer. 9 years is pretty great don't you think? Put another oem belt on and you're good to go for another 9 years. Plenty of websites to choose from for getting an oem belt, just make sure it is a genuine oem part.
Old Nov 11, 2015 | 04:23 AM
switzomatic's Avatar
Get an OEM belt off ebay-they are the way to go on Polaris machines. Might want to look there for a shock as well.
Old Nov 11, 2015 | 10:14 AM
TLC's Avatar
TLC
I tried a "Goodyear Gator Back" and found it hard and slipped where my Polaris OEM never would so I when back. My belt looked good also but for $80 I don't mind changing it every 2500 miles for piece of mind.
You can buy a OEM belt online if you have no dealer nearby.
Here is some oil filters that work.
These Oil Filters have 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket 2.5" to 3.5" long.
Motorcycle Filters.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
WIX PS1358
Recommended filters. All have superior filtering. (I,m told)
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12. Made by Champion.
Bosch 3300, about $6. Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10. Made by Champion.
Bosch 3323, about $6. Made By Champion.
WalMart SuperTech ST7317,about $2. Made by Champion.
Buy these filters Automobile Filters,about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters, about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram PH6607
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
Wix PS1358 (specific for ATV's) What ever that means.
Old Nov 11, 2015 | 09:29 PM
Have ran Gates Belts on several different Makes without a issue, but not Polaris Makes. Curious as to who manufactures the Polaris Belt? If Polaris manufactures their own belts, I would suppose they would have to manufacture belts for other Makes as the manufacturing operation would not be cheap and outsourcing would be profitable. Do they label their belts under another name?
Old Nov 11, 2015 | 11:43 PM
Tried to find out for years as to who the manufacturer was for Polaris belts. Could be Dayco,Gates,Carlisle among a couple others.I always had a suspicion it was either Dayco or Gates,but who knows. When comparing a stock belt to aftermarket belts,the aftermarket belts dimensions were almost always a tad larger,especially wider.They'd work ok on some models,not so good on others. A lot of our customers just came back to stock belts after finding out a lot of the aftermarket belts didn't last as long as the oem.
Old Nov 12, 2015 | 12:10 AM
Defiantly Interesting. Having rode many Polaris atv's, my thought has always been that they are lacking in the CVT engagement process. Yamaha and Suzuki have the smoothest engaging CVTs, as where Polaris kicks in all at once. Mostly due to the centrifugal clutch, prior to the CVT, on the Yama and Suz. The pressure on the Polaris CVT engagement may be the reason for the belt differences?
Old Nov 12, 2015 | 01:18 AM
It's really a matter of give and take with an oil bathed centrifugal clutch prior to the cvt system. The Polaris Hawkeye had this system where the centrifugal clutch took the shock load of engagement first then power went to the cvt clutches. The belt tolerances could be closer,belts were tighter, plus they did have smoother engagement,but you ended up having another system to maintain and replacement clutch packs for most atvs aren't cheap.Give a little in one area and take a way in another. Kinda like the old simple 3 and 4 speed auto transmissions compared to the newer 6 to 8 speed transmissions. The newer ones get better mileage,but the constant down shifting and up shifting gets on my nerves let alone the repair costs when one of these gets past warranty.
ltzbrad
Sep 25, 2015 05:52 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
johnny1982
Sep 13, 2015 07:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Cantbuytime
Aug 17, 2015 06:33 PM
