Need help with sportsman throttle body boot
I picked up a 04 sportsman 700 efi and the throttle body boot is dry rotted right through. I looked up part number and was wondering what the difference is between the 04 and 06 efi boot. The 04 has one part number for boot and it's $45 + shipping. The 06 has the same part number and also another boot part number but it is only $14 for the other one. Just wondering what the difference is if anyone knows. Thanks
Probably a misprint as the part # shows to fit both machines. If you can get it that cheap go for it..
Usage : 1253527
Year Product Model Assembly
2010 MIL MVRS 700 4X4 ENGINE, THROTTLE BODY MOUNTING - M10YH68MA (49MVTHROTTLEBODY10MVRS700)
2009 RGR RANGER 4X4 700 EFI ALL OPTIONS ENGINE, THROTTLE BODY and VALVE COVER - R09HH68/HY68 ALL OPTIONS (49RGRTHROTTLEBODY097004X4)
2009 RGR RANGER 6X6 700 EFI ENGINE, THROTTLE BODY and VALVE COVER - R09RF68AF/AR/AZ (49RGRTHROTTLEBODY097006X6)
2009 RGR RANGER 4X4 700 EFI CREW ENGINE, THROTTLE BODY and VALVE COVER - R09WH68AC/AG/AH/AL/AR/AZ (49RGRTHROTTLEBODY097004X4)
2008 ATV SPORTSMAN X2 700 EFI ENGINE, THROTTLE BODY MOUNTING - A08TN68AX/AZ (49ATVTHROTTLEBODY08SPX27)
2008 MIL MVRS 700 4X4/IDF UPFIT/IDF WINCH UPFIT ENGINE, THROTTLE BODY MOUNTING - M08RH68AA/YH68MI/MW (49RGRTHROTTLEBODY086X6)
2008 RGR RANGER 6X6 700 EFI ENGINE, THROTTLE BODY MOUNTING - R08RF68AD/AF/AZ (49RGRTHROTTLEBODY086X6)
2008 RGR RANGER 4X4 700 EFI/XP ALL OPTIONS ENGINE, THROTTLE BODY MOUNTING - R08RH68 ALL OPTIONS (49RGRTHROTTLEBODY086X6)
2008 RGR RANGER 4X4 700 EFI CREW ENGINE, THROTTLE BODY MOUNTING - R08WH68AG/AH/AK/AR (49RGRTHROTTLEBODY086X6)
2007 ATV SPORTSMAN 700 EFI ENGINE, THROTTLE BODY MOUNTING - A07MH68AX/AY/AZ (4999200229920022D08)
2007 RGR RANGER 700 EFI 6X6 ENGINE, THROTTLE BODY MOUNTING - R07RF68AD/AF (49RGRTHROTTLEBODY077006X6)
2007 RGR RANGER 4X4 700 EFI/LE ENGINE, THROTTLE BODY MOUNTING - R07RH68AD/AG/AH/AK/AL/AO/AP/AW (49RGRTHROTTLEBODY077006X6)
2006 ATV SPORTSMAN 700 EFI THROTTLE BODY MOUNTING - A06MH68AQ/AT/AX/AY/AZ (4999200229920022D08)
2006 RGR RANGER XP 4x4 700 THROTTLE BODY MOUNTING - R06RD68AA/AB/AC/AD/AE/AF (4999202219920221D12)
2006 RGR RANGER 6x6 EFI 700 THROTTLE BODY MOUNTING - R06RF68AA (4999202259920225D13)
2005 ATV SPORTSMAN 700 EFI THROTTLE BODY MOUNTING - A05MH68AC/AS/AT/AU/AW (4994279427D14)
2005 RGR RANGER XP THROTTLE BODY MOUNTING - R05RD68AA/AB (4998269826D12)
2004 ATV A04CH68AU/CU SPORTSMAN 700 THROTTLE BODY MOUNTING - A04CH68AP/AQ/AU/CU (4987468746D07)
Usage : 1253527
