96 xplorer 400L 2 stroke
Old Nov 23, 2015 | 07:31 PM
mopar4u's Avatar
Default 96 xplorer 400L 2 stroke
2,800 miles
Father in laws rig. He said it has been over heating (light came on). I know it has had a small coolant leak for a while, appears to be coming from the left side but I haven't confirmed that.
I can see through the radiator fins, doesn't look clogged. This atv doesn't see mud or rough riding.
I bypassed the thermal switch and the fan came on but it sounded like rocks for bearings. My question is can the bearings be replaced on these motors?
Now I'm not sure if the thermal switch isn't working or if the other two problems are creating the overheating??
Old Nov 24, 2015 | 03:28 AM
Usually the sensor at the top of the radiator shorts out if coolant falls below it not allowing the fan kick on.. If it's leaking coolant fix this problem first. See if you can match this sensor up at an auto supply. Item #8. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Too expensive here and on ebay.Thermal Fan Switch Assembly 1996 Polaris Sportsman Xpress Magnum 300 400 500 | eBay
Plus no the bearings are sealed in the fan motor. Motors aren't cheap for these either.New Cooling Fan Motor Polaris Xplorer Explorer Xpress Express 300 400 500 ATV | eBay Plus don't know if you have enough room around the back of the radiator to use an all in one unit or not like this or a way to mount one up properly.. Automotive Electric Fan 11 1 2 x 12 1 2 Universal Electric Fan Made in USA | eBay
Old Nov 24, 2015 | 05:11 PM
mopar4u's Avatar
Hey opt
I got the fan fixed. Im fairly certain i have it assembled properly. Its pushing air into the radiator, this seem right? Looking at the radiator with fan installed its rotating ccw.
Old Nov 24, 2015 | 06:34 PM
Should be pulling air through the radiator..
Michael Rose
Oct 26, 2015 11:56 AM
r1pilot83
Sep 27, 2015 07:38 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Hw00d
Sep 10, 2015 08:53 AM
polarisrider1203
Aug 29, 2015 07:52 PM
