Scrambler 50 throttle problem
Old Jan 10, 2016 | 11:58 AM
  #21
Berka81's Avatar
The brass screw right above the word "SunWorld" This is the idle speed screw or idle adjuster as it's sometimes called.
If so, is the bad news that absolutely nothing happens when I screw on the screw. I can screw it as far as it goes but it does not affect idling at all. the only thing that happens is that the throttle control is sluggish and will only half , if I screw it out a little so goes the throttle fine again ...
Old Jan 10, 2016 | 12:13 PM
  #22
Then you probably have the throttle cable adjusted too tight or the thumb throttle may be sticking,etc. I'd just have someone look at it if you can't get it adjusted right.
Old Jan 10, 2016 | 12:23 PM
  #23
Berka81's Avatar
yes it is not easy to explain to someone who does not understand ....
but I'm pretty stubborn of me , then you have the patience to guidea me , I will resolve this to the end.
Old Feb 12, 2022 | 07:12 PM
  #24
wshaffer17's Avatar
Default Throttle problem
Ever figure it out? Long shot of an answer but I’m having the same problem.
Sport Quads
Jul 26, 2016 09:25 AM
Michael N Angela Ellison
Jan 9, 2016 03:25 PM
evanmc1994
Where to Ride
Dec 28, 2015 12:42 PM
JayMueller
Dec 25, 2015 11:18 AM
Dec 19, 2015 06:51 AM
