No throttle
Old Apr 21, 2016 | 06:43 PM
200es's Avatar
I was out working on it tonight and tried taking the air box off while running to see if the diaphragm was opening. It pulled up some but not all the way. While giving it gas I pushed the slide up with a screw driver and it reved up perfectly. I've taken out the diaphragm and there were no holes. I've read a lot about the 500 engines being bad for wearing out the exhaust lobes on the cam. Possible reason?
Old Apr 21, 2016 | 07:20 PM
Cams were not normally a problem when the HO models came out in 2001.Cams had also been updated earlier in the Scrambler 500s also. If you can manually lift the slide up and it revs up,then recheck your work from your original post on the carb clean. With the fuel line off the carb,crank the engine over. Should be a steady stream of fuel if the pump is working good. If it's not a limiting problem,then sounds like somethings not correct in the carb.Plus make sue you hooked any fuel/vacuum line back up correctly if you took any of these lines apart.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Apr 23, 2016 | 11:29 AM
200es's Avatar
I pulled the plug yesterday and the new plug was completely black. Too rich?
Old Apr 23, 2016 | 07:45 PM
Yes.. Install a new BkR6ES plug and carb kit and make sure the float is set correct. Carb has to be turned at a 45 degree angle to where the float tab is resting on the needle plunger. Float should be parallel with the carb body. If not,you can bend the tab to set it.Polaris Sportsman 500 Carburetor Repair Kit Fits 2000 2002 Carb Shindy 03 408 | eBay Here's a good write up on the BST40 carb and goes into detail on setting the float among other things to check. On a Ktm,but carb is similar. The BST-40 Bible | Adventure Rider
Old Apr 24, 2016 | 02:00 PM
  #15
gmpoulos@gmail.com's Avatar
Takes ten minutes to pull the rocker cover and check for can wear....for a quick check just compare the distance the rockers travel...it should be the same for ex and intake
grapejuice420
Oct 26, 2017 06:48 PM
LostKeyboard
Apr 26, 2016 08:26 AM
hammerit2
Mar 24, 2016 05:37 PM
madb63
Mar 22, 2016 06:06 PM
INEEDHELPPLZ
Mar 22, 2016 10:05 AM
