2002 700 shift into high
Old May 3, 2016 | 04:50 PM
This gear case was used on the 700/800 Sportsmans and also Rangers until about 2010. Never liked it because of the wave springs and wide shift forks.Changes were made little by little on the internals on later models to help with this,but it's little consolation to owners of early models that have to tear into them for shifting problems.
Old May 7, 2016 | 07:55 PM
m2cyclone's Avatar
Broke one of the press on gears..
Is there a replacement part for 3233913 40T? all the parts books say its obsolete and no one carries one and there is no replacement for it. the 04+ jumps to a 51T.
is there a replacement or am I stuck buying a used tranny and swapping parts?
and if I do buy a used one.. would there be any benefits to going with a newer trans with different gearing?
thanks
Old May 8, 2016 | 07:51 AM
Gear does show NLA. Possible a later model than a 2004 would fit,may take some small modifications. If you stumble upon a cheap gear case these models should have the same gearing as yours as they share the same gear case part number.
Usage : 1341343 Gear Case
Year Product Model Assembly
2004 ATV A04CH68AC SPORTSMAN 700 GEARCASE - A04CH68AC/AF/AH/AJ/AT/AV (4986128612C13)
2003 ATV SPORTSMAN 700 GEARCASE - A03CH68AA/AC/AF/AH/AL (4975557555C13)
2002 ATV SPORTSMAN 700 GEARCASE - A02CH68AA/AB/AC/CA/CB (4966346634C13)
Couple on ebay now.1341343 Polaris | eBay One says for parts,the other says it shifts smooth,but who knows on used parts?
Old May 8, 2016 | 08:07 AM
m2cyclone's Avatar
yeah, found some 02 complete boxes on ebay for 170. guess I'll get one and piece it all together.
Old May 8, 2016 | 10:37 AM
  #15
Wish you luck and keep us updated.
PleasantCrab
Apr 1, 2016 03:31 PM
Whitelx1
Feb 25, 2016 08:02 PM
Whitelx1
Feb 25, 2016 04:57 PM
200es
Feb 22, 2016 12:19 PM
