Sticky Shifter??
High idle can have something to do with shifting,plus if it creeps any at all or if there is any pressure on the driven clutch from worn washers on the drive clutch one way bearing,that can cause problems also. Plus it has the same external shift quadrant that the troublesome 700/800 shared and it may be time to remove the outer cover and clean/grease the shift gears.Item#3.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Internals are similar to this one.Hard to Shift 700 Sportsman 2004 - Polaris ATV Forum
4-tracker
May 30, 2016 09:05 PM
4-tracker
Where to Ride
May 11, 2016 09:38 AM
cswiger
Apr 29, 2016 10:22 AM
