A arm for Xpedition 425
We have used Xpedition which may have been damaged and repaired with parts from another model. Things appear not be lined up properly. We also need a dimension for the front axle shaft. Thanks.
Expedition 425 came out in 2000. Dimensions aren't normally given for the a-arm or the axle shafts but you can go to the Polaris Parts Catalog and see what models interchange parts. Find the part #,scroll to the right and click on usage. Shows what machines and year models use the same part.Can help on tracking down new or used parts.
Browse
Here's the right front a-arm for your machine as an example.
Usage : 2200628
Year Product Model Assembly
2002 ATV SPORTSMAN 700 A-ARM/STRUT MOUNTING - A02CH68AA/AB/AC/CA/CB (4966346634B12)
2000 ATV XPEDITION 325 A-ARM/STRUT MOUNTING - A00CK32AA (4954895489B013)
2000 ATV XPEDITION 425 A-ARM/STRUT MOUNTING - A00CK42AA (4949304930B013)
1999 ATV BIG BOSS 500 6X6 A-ARM/STRUT MOUNTING - A99AE50DA (4949204920b012)
1999 ATV INTL BIG BOSS 500 6X6 A-ARM/STRUT MOUNTING - A99AE50DA (4949204920b012)
1999 ATV XPLORER 300 A-ARM/STRUT MOUNTING - A99CC28CA (4949484948b013)
1999 ATV MAGNUM 500 A-ARM/STRUT MOUNTING - A99CD50AA (4949254925B014)
1998 ATV NORWEGIAN BIG BOSS 500 6X6 A-ARM/STRUT MOUNTING - S98AE50E (4946394639b012)
1998 ATV Swedish Big Boss 500 6X6 A-ARM/STRUT MOUNTING - S98AE50E (4946394639b012)
1998 ATV BIG BOSS 500 6X6 A-ARM/STRUT MOUNTING - S98AE50E (4946394639b012)
1998 ATV NORWEGIAN MAGNUM 4X4 A-ARM/STRUT MOUNTING - W98AC42A (4945214521B011)
1998 ATV SWEDISH MAGNUM 4X4 A-ARM/STRUT MOUNTING - W98AC42A (4945214521B011)
1998 ATV MAGNUM 4X4 A-ARM/STRUT MOUNTING - W98AC42A (4945214521B011)
1997 ATV Big Boss 6x6 400L A-ARM/STRUT MOUNTING BIG BOSS 6X6 400L W97AE38A (4940814081B011)
1997 ATV BIG BOSS 6X6 400L A-ARM/STRUT MOUNTING BIG BOSS 6X6 400L W97AE38A (4940814081B011)
1997 ATV NORWEGIAN MAGNUM 4X4 A-ARM/STRUT MOUNTING Magnum 4X4 W97AC42A, Swedish Magnum 4X4 S97AC42E and N (4940834083B011)
1997 ATV SWEDISH MAGNUM 4X4 A-ARM/STRUT MOUNTING Magnum 4X4 W97AC42A, Swedish Magnum 4X4 S97AC42E and N (4940834083B011)
1997 ATV MAGNUM 4X4 A-ARM/STRUT MOUNTING Magnum 4X4 W97AC42A, Swedish Magnum 4X4 S97AC42E and N (4940834083B011)
1997 ATV SWEDISH MAGNUM 6X6 A-ARM/STRUT MOUNTING Magnum 6X6 W97AE42A and Swedish Magnum 6X6 S97AE42E (4940754075B012)
1997 ATV MAGNUM 6X6 A-ARM/STRUT MOUNTING Magnum 6X6 W97AE42A and Swedish Magnum 6X6 S97AE42E (4940754075B012)
1997 ATV SPORTSMAN 400L A-ARM/STRUT MOUNTING Sportsman 400L W97AC38C (4939673967B013)
1996 ATV NORWEGIAN 400L 6X6 A-ARM/STRUT MOUNTING 6X6 400L - W968740 and 6X6 400L Norwegian - N968740 (4935963596B012)
1996 ATV 400L 6X6 A-ARM/STRUT MOUNTING 6X6 400L - W968740 and 6X6 400L Norwegian - N968740 (4935963596B012)
1996 ATV SWEDISH MAGNUM 4X4 A-ARM/STRUT MOUNTING Magnum 4x4 W968144 and Swedish Magnum 4x4 S968144 (4936053605B009)
1996 ATV MAGNUM 4X4 A-ARM/STRUT MOUNTING Magnum 4x4 W968144 and Swedish Magnum 4x4 S968144 (4936053605B009)
1996 ATV SWEDISH MAGNUM 6X6 A-ARM/STRUT MOUNTING Magnum 6X6 - W968744 and Magnum 6X6 Swedish - S968744 (4936073607B012)
1996 ATV MAGNUM 6X6 A-ARM/STRUT MOUNTING Magnum 6X6 - W968744 and Magnum 6X6 Swedish - S968744 (4936073607B012)
1996 ATV SPORTSMAN 4X4 A-ARM/STRUT MOUNTING Sportsman 4x4 W968040 (4935943594B013)
1995 ATV NORWEGIAN MAGNUM 4X4 A-ARM/STRUT MOUNTING - W958144 (4926862686c005)
1995 ATV SWEDISH MAGNUM 4X4 A-ARM/STRUT MOUNTING - W958144 (4926862686c005)
1995 ATV MAGNUM 4X4 A-ARM/STRUT MOUNTING - W958144 (4926862686c005)
1995 ATV BIG BOSS 6X6 400L A-ARM/STRUT MOUNTING 6x6 400L - U.S. W958740, SWEDISH S958740 and NORWEGIAN (4930273027B013)
1995 ATV SPORTSMAN 4X4 A-ARM/STRUT MOUNTING Sportsman 4x4 W958040 (4930403040B013)
Browse
Usage : 2200628
