570 adc (2016)
Old Feb 4, 2017 | 08:09 PM
RticKwad's Avatar
Runs Stealth!
In the past they used 8mm plugs. Obviously I haven't worked on one,but the fill plug on all the other models was just as had to get to.I used an 8mm socket on an extension to get to it.You can use a tube with a small funnel to fill it or they may make a funnel small enough to work if similar to the other models I did.Yes the demand Drive fluid for the front diff,Agl for the gear case.
Cool, but i cant seem to get to the plug, how do i post a pic on here now?
Thanks OPT!!
​​​​​​​R'
Old Feb 4, 2017 | 08:13 PM
On some I had to remove radiator shielding to get to the plug. Don't know if that's what in the way on the newer 570.
Old Feb 4, 2017 | 09:09 PM
RticKwad's Avatar
Runs Stealth!
I think the only way is from bottom if skid plate is off? I need to confirm that.
jplowing
Oct 5, 2016 08:25 AM
ATCFLYBOY02
Oct 2, 2016 09:25 AM
bradleyheathhays
Sep 10, 2016 07:49 PM
1gr8bldr
Sep 9, 2016 02:39 PM
Wade87
Sep 6, 2016 03:50 PM
