Question about water pump impeller
#52
Well I got the shindy carb kit and the fuel mixture screw isn't the same as what was in there, the one that came in the kit isn't a needle like the picture I posted above the other day?? Says 03-05 scrambler and 03-05 sportsman on the package
#53
If the kit shows 03-410,that's supposed to be the right kit for the Sportsman and the Scrambler. Shindy Products, Inc. - ATV Replacement Parts If it's not right contact the seller.
#55
If you're talking about the pilot or fuel screw located at the front of the carb, Polaris and other online suppliers don't list this part separately as it was originally under a "tamper proof" block off plug. Even though the one that was supplied may be different,see if it screws into the same spot with the new spring,washer and o-ring.. Set at a base of 2 turns out.
#57
IF the new one in the kit won't work you can clean the old one up and use the new spring,washer and o-ring...This one that you posted.
#58
Yes that is the one that was in there. It is not reusable because previous owner broke the head off the screw and I had to use an easy out to remove it. So if im understanding you, I can use the screw they sent as long as it fits? It doesn't need the needle?
#59
