Sportsman 500 only runs while choke is on
Anyone have any thoughts on what would cause a 2004 Polaris Sportsman to only run when choke is on slightly? As soon as I push choke in all the way the bike stalls.
I've run Seafoam and other fuel stabilizers through the gas. I changed the fuel filter. I changed the spark plug. I ran it with the air filter off briefly to see if it was airflow, and the filter looks clean anyway. I even rev'd it very high and then closed off the air intake to flood the carburetor and then let it sit. Nothing is helping. I tried to turn the throttle screw to up the idle and no help, seems to just runs hotter. So I pulled carburetor off and cleaned it but wasn't really any gunk or dirt except on the main needle, but wiped all that off and still runs only with choke slightly out.
Still sounds like you have a pilot jet stopped up. Seafoam or any other carb cleaner may not help that as you'd have to physically clean any blockage.Only running on choke is a good indication of that or something else fuel/carb related. To rule out a fuel pump,pull the fuel line from the carb and crank the engine over. Should be a steady stream of fuel.If you have to pull the carb one more time install a new carb kit and make sure every passage is blown out. This way you can at least eliminate the carb.Shindy Carburetor Rebuild Kit - Sportsman, Scrambler 500 2003 2004 2005 Carb | eBay
Sportsman 500 only runs while choke is on - video
Thank you old polaris tech. Here's what the fuel flow looks like when cranking it over. Is that good enough flow?
" type="application/x-shockwave-flash" width="425" height="350">
