Polaris Scrambler 500 4x4 frame help
Frames have different part numbers.Similar,but what other differences on the frame other than they had different gear shifters and mounting brackets, I don't know.This difference alone would cause a part number change between the two frames.Shift box mounts could be changed,but still may be other differences.
Take look on ebay look them the 2 frames up compare the pictures to each other you should be able to get a better idea of what they look like and zoom in on them stripped down powersportsnation.com [got stuff from them before]has a couple then Take a chance if you think its close you might get lucky. I'de just make sure you can return plow mount if not right, maybe distributer can help? be careful unpacking [if you need to send back] and see if it matches up if they say you cant wont let you return it try to find distributer that will just my opinion good luck
