chain adjustment
Old Apr 20, 2001 | 06:02 PM
jetjock's Avatar
I have about 100 miles on my '01 scram 2x4 and want to adjust the chain...what the heck do u need to do...i tried loosening the u bolts holding the the rear assembly in place ....what else did i miss?...hurry i need to do this soon...riding this weekend
Old Apr 20, 2001 | 06:51 PM
OffRder15's Avatar
You have to losen the two bigger bolts on the housing AND the caliper bolts(the bolts holding the caliper on, located under the axle to the right of the disk). You can see one of the caliper bolts, the other is under a little bit more. I use a huge pair of channel lock's to rotate the axle housing. You have to rotate foreward to tighten, backwards to losen I think. Just make sure you make all the bolts nice and tight when you're done.It's really really easy once you get the hang of it!
Old Apr 20, 2001 | 11:06 PM
TheQuadfather's Avatar
There is also a hole between the axle and the rear sprocket. You can insert a phillips head screwdriver into it, rotate the wheels until it lines up with another hole on the axle carrier, the screwdriver will go into that hole as well, and you can rotate the rear wheels until you get the desired tension, then retighten the bolts.
Old Apr 21, 2001 | 08:48 PM
motorman's Avatar
check the adjustment after you are done by pulling down on the suspension with a ratchet tie down to make sure the chain is not to tight.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
goosemasterkl
Aug 23, 2015 11:36 AM
