Polaris AWD problem
Old Jun 2, 2018 | 03:40 PM
  #31
crescendo's Avatar
Hi Mustangpaul, Well you certainly have a rodeo going on, Check to make double sure that the five roll pins on each side of the ring gear are indexing into the five recesses on each hub, if they are I would get a caliper and measure the new cage and compare to the old providing it's not broken, perhaps the new cage was miss packaged ? probably unlikely but worth checking. When reassembling the pinion shaft should turn easily both directions if you feel a tight spot than something is in a bind, also, turn the pinion at least four revolutions this will turn the ring gear one complete rev. Don't give up its bound to be something rather simple. Let me know what you come up with............
Old Jun 2, 2018 | 04:17 PM
  #32
Mustangpaul's Avatar
Just found my box the roller cage number was sb301f from east lake axle
Old Jun 2, 2018 | 06:15 PM
  #33
Just put a thin washer between the 2 wheel hubs where they meet,that gold coloured bushing I can move in and out a bit about 1/8th so I put a thin washer there and everything worked perfect.on Monday I will go to parts shop and get a good washer or a proper bushing like the one I have just a shade longer.question for you, on your 2 hubs where the axles go in, is one hollow on yours, you can see right through it, cause on the manual pictures for this bike it’s not?
Old Jun 19, 2018 | 10:46 AM
  #34
Where your axle goes in on each hub, can you see all the way through on one of them.thx
Old Jun 21, 2018 | 09:38 AM
  #35
crescendo's Avatar
Hi Mustangpaul, Sorry for the late response, no you cannot see thru either of my hubs with the axles removed, there is a solid bottom on each hub.
chikester
Oct 9, 2018 12:13 PM
trbojet1
Oct 12, 2017 04:33 PM
650bomber06
Oct 11, 2010 08:03 PM
02sptsmn500ho
Apr 13, 2008 10:33 AM
bbrc
Jan 17, 2005 10:25 PM
