Polaris AWD problem
Hi Mustangpaul, I don't know if this will help, I'm having a similar problem and am now leaning towards my armature plate being magnetized and not fully releasing even when the switch is in 2wd mode, also I have seen on the internet where the spacer plate that's the one that has five approx 1/8" holes around the perimeter needs to be removed when replacing the carrier assembly. I'm also going to tap on the inner race on both internal bearings that are pressed on the left and right hub to ensure that they are seated against the shoulders of their respective hubs. When complete I'll post the results.
#15
There are two hubs, these are the parts that your axles spline into that you have to pry out when you remove the differential, there is a ball bearing on each hub this is what I was referring to there is an inner race that is pressed tight on the shaft, this is what I will drive against with a punch and hammer, a press would be a better option but I don't have one, a word of caution don't hammer on the outer race as the ball bearings within will be taking all the shock. you might check your armature plate for any kind of magnetism with say a paperclip I don't know how much is too much I guess the thought is that any voluntary interaction that the armature plate may have will keep the machine partially engaged in 4x4. As stated in an earlier post, in 4x4 I can ease the machine up to a tree with one wheel and it will climb right up the tree just as Polaris claims it should, then switch to 2x4 and ease up to the tree just the rear wheels everything works as it should, take it for a test ride and the front end is fighting me like the front drive hasn't disengaged fully, don't know if this is similar or not to your issue Mustangpaul, I'm still looking to............
#18
#19
#20
