03 Polaris Coolant
Old Jul 1, 2018 | 02:44 PM
Mitch Luns's Avatar
Default 03 Polaris Coolant
so I was reading about everyone losing coolant and many replies say add water this and that. Why would you not use a non silicate antifreeze coolant? Is any one actually using water as coolant? If not what type coolant are you using? Polaris 700 Sportsman
Old Jul 1, 2018 | 02:50 PM
user493's Avatar
Moto Psycho
I'm using the old style Prestone or generic equivalent 50/50 mix in my ATV. I've never used anything else in any of them.
Old Jul 1, 2018 | 07:42 PM
Mitch Luns's Avatar
Default Coolant
the dealer says to use non-silicate coolants or it will mess up the water pump. But I’m quite sure water is not the answer. Thank you kindly for the response
Old Jul 1, 2018 | 10:58 PM
user493's Avatar
Moto Psycho
Water is definitely not right for it. What does your owner's manual say? Mine says to use Polaris Premium 60/40 or a 50/50 mixture of high quality aluminum compatible anti-freeze/coolant and distilled water. If the old greenish color coolants weren't compatible with aluminum, I think we would have heard about it by now. You can't use it in newer cars and trucks with higher revving and hotter running engines, but I don't know how that applies to old ATVs. Polaris also recommends that you drain and refill your cooling system every 2 years. I'm 8 years overdue on mine. If it overheats this summer I'll change it.
hondafl350
May 1, 2009 12:55 PM
overthehillsgangATVer
Aug 26, 2008 12:22 AM
derrel
Jan 26, 2006 01:09 PM
subfan
Mar 21, 2001 01:37 AM
