2011 330 trail blazer rear bearing replacement
i have my axle out and have removed everything from it
but can't get off part #10 or #19. I have tried knocking off part 19 and it has move about 1 inch away from center. before i keep trying to move it, i can't get part 10 to move at all. any help would be great.
this is the diagram on bike bandit to show what i mean.
https://www.bikebandit.com/oem-parts...8165#sch667263
i guess what i'm saying is the the inner race is stuck on the axle along with the sprocket. is there some type of puller that will reach the 18 inches or so or do i just have to slide o pipe over the axle that is still small enough to be able to just hammer them both off? i sprayed them down with PB blaster and lubed up the axle, they don't want to move.
Thanks, I guess I wasn't hitting it hard enough. So got everything off and everything back together but might have a new problem. The chain sprocket can slide @ 1/4 inch between the snap ring and the carrier housing. The teeth on the axle are against the bearings and the is now way to tighten the other side any more. I did not notice if it was this way before I started taking it apart but since the bearings were completely shot, it was all flopping around anyway. I have put all the parts in, they are all new, the bearing carriers are seared and when I push the sprocket in by hand it fits perfect. I double check the bearings to another set I have and they appear to be exactly the same size. Any suggestions? Thanks
tripd
Jul 22, 2009 05:49 PM
tripd
Jul 22, 2009 10:44 AM
