No running lights, 2009 outlaw 90
Old Sep 11, 2018 | 06:42 AM
lief's Avatar
Rocker
Default No running lights, 2009 outlaw 90
Hello,
I have a 2009 outlaw 90, just get it, no manual (ordered) and just got it running. Set float, attached black wire on CDI, set throttle slop. Now it starts and idles great without any choke cold. Well 70 degrees.
I do not have e any running lights. The break lights work and there is power for everything else. As in horn, starter, back break light. The nutral green light works.
The orange reverse light also works although I need to wiggle the shifter.
When do the lights come on? With the key?
Is there two lights in the tail light? running and break?
does anyone know where the power comes from fro the running lights (headlight and tail light)
Thanks, first post
Old Sep 11, 2018 | 07:28 AM
lief's Avatar
Rocker
added info:
checked the two wires each front bulb, checked voltage wire to wire, no DC voltage.
checked batter ground to each wire, no dc voltage.
will remove back bulb (tail Light) today and check to see if it has 2 filaments and 2 power wires going to it.
Old Sep 11, 2018 | 08:58 AM
lief's Avatar
Rocker
got it, the stop light is 12vDC, the running lights are 12V AC, greased up the voltage regulator plug and everything is working.
the tan/red wire for the lights origin is at the regulator. The other black is ground/common.
Old Sep 11, 2018 | 09:21 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
Welcome to the forum. I didn't even know they had headlights. Some kid's quads didn't because the manufacturers thought no one would be riding them at night. I have my headlights on most of the time when I ride in the daytime because it's easier for other people to see me.
KidFrost
Jun 8, 2011 07:49 AM
murox
Polls
Mar 19, 2010 09:48 PM
Jthoms1
Utility ATVs
Nov 7, 2008 07:16 AM
Indianarider
Aug 14, 2008 01:08 PM
