2008 800 touring electrical help needed
So here is what I know and have done. 1st key has power all fuses except acc have power. But no instrument cluster or crank. If I use a jumper wire from main power to acc fuse have cluster and machine will crank. And run. My question is am I needing to replace the ignition or is this a wiring issue. Where does acc fuse pull its power from. I would suspect the ignition but am not in the habit of throwing money at things in hopes of a fix.any feedback would be greatly appreciated
Looks like the red black wires(2 wires) form the key supply voltage to the left hand handle bar switch, then in the on position on the handlebar switch it sends the voltage to the red/white wire coming out of the handlebar switch, it then goes to a splice where there are 7 white/red wires, then to the acc fuse.
Check the left hand handlebar switch connections, corroded or dirty my guess.
F
F
lippsenator
Feb 18, 2008 04:06 PM
