Strong smell of gas
Old Nov 10, 2018 | 03:17 AM
Fadetoblack188's Avatar
Default Strong smell of gas
My 02 scrambler has a strong smell of gas just sitting in the garage after riding? What could be causing this?
Makes the the whole house small
where do I start? I don’t think it’ has a leak.
The gas gas and oil are mixed. That wouldn’t cause it would it?
Old Nov 10, 2018 | 04:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it might be the float is sticking open in the carb, but you would be seeing gas come out some where the same goes with the fuel shut off on the tank might be leaking by. check for wetness and use the nose to try to pin point the strong smell.
Old Nov 10, 2018 | 05:14 PM
Ok so it looks like the seal on the air clean is pushed out and my gas/oil mix is comming out??? I don’t think that should have the fuel mix in there. I will obviously fix the seal but why is the fuel even getting in there?
also I noticed the crank cAse duct hose that runs from the crank case to the other side has two big tears in it. Would this affect anything?
schildi
Feb 24, 2016 09:25 AM
Bone1208
Nov 27, 2005 08:35 PM
hondabuster
Jan 12, 2005 03:43 PM
hondabuster
Jan 10, 2005 12:22 PM
