New top end, low compression
Old Dec 2, 2018 | 04:44 PM
woody1189's Avatar
Default New top end, low compression
Hi, new to the forums. So I Installed a wiseco piston, bored correctly, installed correctly, all new gaskets, and torqued right. Yet it only makes 65psi? What could possibly cause this?
Old Dec 2, 2018 | 08:07 PM
94harley's Avatar
What is it?
2 stroke? Reeds broken, debris holding one open?
Old Dec 2, 2018 | 09:43 PM
woody1189's Avatar
Originally Posted by 94harley
What is it?
oh, sorry. Polaris trailblazer 250, 74mm, carb cleaned, new piston, fresh bore, new rings, gaskets. Yet to touch the crank seals. Thanks
Old Dec 2, 2018 | 11:09 PM
94harley's Avatar
Crank seals will affect how it runs, but not compression in my opinion. Carb is the same situation. If you only have 65 for compression, I'd tear it back down. Something is broken, cracked, or warped. Piston in backwards???
Old Dec 3, 2018 | 02:19 AM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
"I'd tear it back down." Yep.
Old Dec 3, 2018 | 05:44 AM
woody1189's Avatar
it was all put together right, which is why I don't understand it. Head warped maybe?
Old Dec 5, 2018 | 02:24 PM
DirtDevil101's Avatar
try pouring a bit of 2-stroke oil in the cylinder, replace plug and crank it slowly...if oil seeps from the jug/head then bad gasket or machining...if you can crank it and no seepage then you have a piston/ring to cylinder clearance issue...
Hopefully you had the throttle wide open when checking the compression...
Drosner
1) Engine problems..
Dec 2, 2018 09:01 PM
conehead427
Sep 30, 2008 12:19 AM
DarkManX
Sport Quads
8
Sep 18, 2004 04:36 AM
H300F
8
Jul 30, 2000 09:32 PM
