driven clutch removal
Old Aug 29, 2009 | 02:46 PM
subby_nut's Avatar
ya i think i did,is there gonna be anyway for me to re thread them or am i ****ed and have to rebuild with a new crank?
Old Aug 29, 2009 | 02:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
w/ out knowing the extent of the damage to them there is no way of telling until you get to see them. if not to bad then i would say just to re tap them out might do just fine. cross your fingers and hope.
Old Aug 29, 2009 | 03:01 PM
subby_nut's Avatar
cool man thanks,any hints on how to breack it,should i tear the spring and stuff off first i was thinking of using a cut off wheel or a sawzall or chizzle the cracket part
Old Aug 29, 2009 | 04:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would strip the clutch of all the parts if possiable. its just the back(toward the engine) sheeve that would have to be cut as the clutch is on a tappered crank shaft and only about 1" or so is holding it on.
Old Aug 31, 2009 | 05:12 PM
  #15
subby_nut's Avatar
do i need a clutch puller to stop the clutch from springing at me while im taking of the front of the driven clutch??? or can i just do it slow ?? with a socket??
Old Aug 31, 2009 | 07:33 PM
  #16
stendori's Avatar
Super Quad Patrol
I'm watching you!
the driven(secondary) clutch is the large one connected to the trannsmission and only has a center bolt that holds it on and you could hold the brake while in gear to hold that clutch from spinning. the primary(drive) clutch you already have the center bolt out so no worry of holding that clutch for the 6 small ouside bolt that holds the cover on.
Old Aug 31, 2009 | 10:23 PM
  #17
subby_nut's Avatar
so when i take those 6 off its not gonna spring out at me?? i wanNA TAKE IT APART AS MUCH AS I CAN BEFORE I TRY TO BREACK THE BACK PEACE OFF
Old Sep 1, 2009 | 08:10 AM
  #18
sassee's Avatar
3/4 inch bolt worked great for me couple years ago. I needed to get the clutch off on a Saturday afternoon and i knew the only Polaris dealer close to me was an hour away and it was time for them to close. I called the owner and he told me to use the 3/4 bolt, it would work fine, and it did.
Old Sep 1, 2009 | 03:40 PM
  #19
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you read the whole thread you'll see he sort of tried that w/ a piece of metal in the middle behind the threaded bolt and ended up bending the metal inside and now the metal is stuck inside. as far as the 6 bolts, yes its under a little spring pressure, but not very much as you can easiely hold it w/ your hand. take out all of them except 1 each on 2 sides of the spider and then remove them both some waht evenly so it comes off smoothly and not at an angle.
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
