Punctured CV boot
Old Apr 30, 2001 | 02:49 PM
famosrichit's Avatar
I was out riding this weekend and ran into a stick that pierced my CV boot and boot guard. I am almost sure that I have seen an upgraded boot guard that is stronger than the plastic factory one. Does anyone know of a website that I can find this at? Any suggestions are appreciated.
Also I have a installed a Warn A2500 winch and wanted to know if anyone has installed a second battery. If so where did you mount it at?
Thanks
Old Apr 30, 2001 | 07:10 PM
PolarisMan's Avatar
i tore the rear inside boot for my sp500. the black rubber peice is just torn. i havent rode since it happened. i am pretty sure it happened b/c of wear. b/c the other side has a definite crease. and it looks like it could tears any time. should i just get new boot covers, for bother sides?
Old Apr 30, 2001 | 07:52 PM
soggyrider's Avatar
Try Highlifter.com
Old Apr 30, 2001 | 08:33 PM
fullthrottle's Avatar
Tore mine over the weekend also.I was wondering if you need the special tool for the clamps or if a pair of crimpers or needle nose plyers will do? I ordered my cv boots($29.00 each) from EPI along with much needed outer tie rod ends($42.00 each).
2000 xplor 400 4x4
Old Apr 30, 2001 | 09:39 PM
tmbk2's Avatar
Those cv boots shouldn't cost you more than $8-10 bucks w/o new clamps. I saw the prices in EPI and can't understand why they are so high...
If your lucky you can get the clamp on and off with a pair of channel locks and a flat head screw driver. They are only good for or two changes before they get all bent out of shape. They special pliers would be a nice.
Polaris makes a full set of plastic skid plates and a-arm guards that work real well.
Old May 1, 2001 | 01:20 AM
PENNZILLA's Avatar
TRY PARTS UNLIMITED FOR THE ALUMIUNM GUARDS. WATCH WHEN YOU PULL THE SHAFTS APART TO CHANGE THE BOOTS. TAKE A PERMENANT MARKER AND MARK BOTH SO YOU LINE THEM UP THE SAME WAY WHEN YOU PUT THEM BACK TOGETHER. I KNOW THE REAR AXLES ARE SPLINED IN A SPECIFIC ORDER ON THE 500 SPORTSMAN AND MOST SHAFTS ARE. IF YOU DON'T GET THEM LINED UP THE SAME THE MACHINE WILL WOBBLE AND MAKE NOISE.
Old May 1, 2001 | 10:54 AM
xepathfinder's Avatar
Polaris CV boots are only around 10 dollars, I tore a rear one and it was 50 dollars to fix at the dealer, one hour labor and 10 bucks for the boot.
Old May 1, 2001 | 12:33 PM
dhenricks's Avatar
I have torn three (3) front boots on Scrambler 500's and replaced them myself. I did buy the boot clamp tool and it really helped. The clamp tool was $25, but well worth it. You can snap the shaft out of the wheel cv joint (snap ring) with a quick jerk and then do the same to put back in place. No alignment of shaft is needed. Hope that helps. Boot kits with clamps and greese pack are $20-$25.
Old May 1, 2001 | 02:19 PM
pflueeb's Avatar
hey---what is EPI!!!! Where can I buy cheaper Polaris parts than at my horribly-overpriced dealer? Anyone know? Thanks!!
Old May 1, 2001 | 03:56 PM
dhenricks,
Where did you find the boot kit and clamp tool that cheap! Also doing this for the first time how long will it take to do the job.(Both sides).
fullthrottle
2000 xplor 400 4x4
