TB rjumping
Old May 3, 2001 | 08:40 PM
trlblazr250's Avatar
has anyone tried to jump any big jumps on their Trail blazers with stock shocks? i want to know if i can or if the front end is to hevy or something might meess up?thanks
Old May 3, 2001 | 09:11 PM
x_scrambler3's Avatar
I do all the time. Im running stock struts an used to use the stock rear shock to till I broke it in half. you can hit some pretty big jumps mine has all way handled good in the air. If you have not done any big jumps try to start on smaller one first to test the shocks on how much of a hit they can take.
Old May 4, 2001 | 11:20 PM
00TB250's Avatar
My fronts are still stock but I put a Fox 1.5 on the rear. It greatly improves landings, worth the $ if you like jumping, even the little stuff will cause you to bottom out with the stock rear.
If you do anything to the front, I think the thing to do would be heavier springs along with new struts.
