03 Polaris Pred 500 carb problems
Old Dec 30, 2024 | 10:38 AM
fred becker's Avatar
Default 03 Polaris Pred 500 carb problems
Having problems getting my predator to run correctly
Was sitting for around 10 years. So I cleaned and rebuilt the carburetor and replaced the fuel pump. Fires up and idles strong but dies and coughs smoke out of the breather on carb when given the slightest throttle. Checked the spark plug(stock) and it was black(replaced with NGK iridium). Also lowed the needle hight 1 and 2 levels to see if that would lean it out. That didn’t seem to help anything. Are there any vacuum lines on the carb that I’m missing? can’t find any schematics that show anything. And just stuck on what to try next. Note: not very experienced on this hence it’s for a school project and my instructor is lost to.
Old Dec 31, 2024 | 09:57 AM
papa hogg scoot's Avatar
Loved
Community Favorite
If you leave choke on half choke does it run better after throttle up? check intake manifold for leaks[spray with wd40] see engine dies.Does it have a good air filter?
Buckshot1
Oct 27, 2015 08:10 PM
Trevorh19
Nov 9, 2010 09:45 PM
smokeyandthebandit
May 12, 2010 10:17 PM
want2Bmuddy
Oct 2, 2004 12:15 AM
