The heel clicker results are in!
Old Jun 17, 2001 | 03:25 AM
motorman's Avatar
i have EBS installed on my 96 400 xplorer and i have 3000 miles on it and a lot of my running is done in deep woods cutting new trails. i always use low range in these conditions and my clutch sheaves shows no wear. is your clutch cover sealing well, because dust and dirt could cause this wear. also i wonder if different belts could cause this problem.
Old Jun 17, 2001 | 03:29 AM
motorman's Avatar
to see how far the belt is climing just put stripes in the clutch sheaves with a magic marker and see how far up the mark gets rubbed off.
Old Jun 17, 2001 | 07:01 AM
MUDDY4LIFE's Avatar
Motorman,
my belt cover is sealed extremly well,it has to be for the simple reason that I Mud alot and am often in deep water,so a sliping belt is not someething I want or desire.In fact,I usually change the cover seal after removing the black cover everytime.
Bill
Old Jun 18, 2001 | 02:35 AM
MudStud's Avatar
How about a web site for the Heel clickers... I am looking into clutching my sp500. I am looking at the HPD and the AAEN. is it better to mix and match?? I also want to put the HPD rollers in the back to get rid of that ebs
Old Jun 18, 2001 | 12:24 PM
  #15
Thor's Avatar
<< Puller,
...Im not so sure why the clutch sheeves are wearing like they are,but even on my Sportsman ,the wear was the same and the primary clutch had to be replaced...
Bill
Do you think that the added drag of the 26&quot; tires and the higher (aggressive) engagement point of the green spring had anything to do with it?
Old Jun 18, 2001 | 02:13 PM
  #16
MUDDY4LIFE's Avatar
Thor,
I beleive that the tires may have something to do with it,but im not convinced that the green spring does.Alls the green spring does is raise the engagement speed and it allows the belt to actually ride higher up in the primary clutch before it engages.And my wear is at the bottom of the primary sheeves.
I ordered the very best[and expensive] sprockets and chain from Sidewinder.I went with a 38 tooth rear sprocket [instead of the stock 36 tooth]to help out the low end and summize the added drag that the tires give.I hope that this is the answer,things are getting very expensive on this toy,hope it works,
Bill
Old Jun 18, 2001 | 05:37 PM
  #17
Thor's Avatar
Bill,
You lost me a little bit on that one. Wouldn't the belt engage in the same place on the sheaves only at a higher rpm? It seems that it would engage in the same place but move more rapidly up the sheave due to being more in the power band.
I sure hope that it all works out for you. It certainly seems to get to be expensive when a person pushes the envelope and does a little innovating/pioneer work.
You should have more acceleration going from the 2.77:1 gear ratio up to the 2.92:1. Good luck
Old Jun 18, 2001 | 06:54 PM
  #18
MUDDY4LIFE's Avatar
Thor,
You are correct and thanks for clearing that up for me.My sprockets came in today and I hope the new clutch comes in tommorrow.
I do think that the new 38 tooth sprocket will help,hope so.
Bill
salixair
Nov 3, 2015 08:25 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
